round a number with a x.x precision
La Tenaille
Unread post by La Tenaille » 10 Sep 2013, 17:42
I'm looking for a way to round a number with a x.x precision. It's to send a precise tempo from midi clock to master.
Can you help ?
Unread post by nay-seven » 10 Sep 2013, 18:20
yes, actually the round module don't have settings to choose, so the workaround is to insert a fader with precision x.xx after your value .?
La Tenaille
Unread post by La Tenaille » 10 Sep 2013, 22:46
I already tried this, but I don't know how to get the value out of the rounding fader :|
Unread post by nay-seven » 10 Sep 2013, 23:18
from its outlet..?
where do you want to send this value..?
La Tenaille
Unread post by La Tenaille » 10 Sep 2013, 23:27
to master sync tempo. The fader is rounded, but its fader outlet isn't...
Unread post by nay-seven » 10 Sep 2013, 23:49
ok, try fader > float to string ( precisionx.x) then a strings to float > tempo
Unread post by grego mondo » 11 Sep 2013, 07:59
I would do like that :
*10
round
/10
maybe not so nice but efficient ...
La Tenaille
Unread post by La Tenaille » 11 Sep 2013, 10:08
both work fine. Thanks for your help :)
ceasless
Unread post by ceasless » 11 Sep 2013, 10:53
You could also use the 'trunc' module, if it is only important that the number lose it's decimal place (and not that you need the logic where 0.5 = 1, 1.5 = 2). With trunc 1.1-1.9=1,2.1-2.9=2, etc.
La Tenaille
Unread post by La Tenaille » 11 Sep 2013, 14:14
Hi ceasless,
I need a precise tempo. Trunking is not precide enough and I can hear the decay when using slicers or short delays.
Unread post by bsork » 11 Sep 2013, 17:24
If you want rounding to one decimal, multiply the number with 10, round that, and then divide by 10.
La Tenaille
Unread post by La Tenaille » 11 Sep 2013, 18:25
grego mondo wrote:I would do like that :
*10
round
/10
:P
Unread post by bsork » 12 Sep 2013, 08:41
*10
round
/10
:P
Oooops! Didn't see that...
Unread post by grego mondo » 12 Sep 2013, 12:57
Anyway, it's always nice to see others have the same logic as you, it reassures !!
Users browsing this forum: Bing [Bot] and 102 guests
