Mobius plugin and Usine 6 : MIDI troubles
La Tenaille
Unread post by La Tenaille » 31 Aug 2013, 11:30
I can't make Mobius VST receive or send Midi messages with Usine 6. It worked fine with Usine 5.8.
Do you have the same trouble ?
Unread post by nay-seven » 31 Aug 2013, 12:37
I'll try more , but it seems that I have the same result ( Mobius v 2.5)
La Tenaille
Unread post by La Tenaille » 31 Aug 2013, 13:14
ok, thanks for checking :)
seamus
Unread post by seamus » 01 Sep 2013, 14:37
It works for me. Möbius is jbridged and I use a midi bus to send the midi.
Unread post by nay-seven » 01 Sep 2013, 19:51
This bug will be solved in the next release
La Tenaille
Unread post by La Tenaille » 01 Sep 2013, 21:29
Great new thanks :)
seamus
Unread post by seamus » 02 Sep 2013, 02:36
Are you on Mac or windows ?
Windows 8 jbridged in latest 64 bit hollyhock with midi ox sending to a midi bus like midi yoke works.
Although möbius 2.5 has weird graphics anomalies in windows 8 it works fine
La Tenaille
Unread post by La Tenaille » 02 Sep 2013, 12:04
I use hollyhock 32bits on windows 7 with midi yoke.
Perhaps jbridge helps solving the trouble, but I don't want to use it ;)
hesspet
Unread post by hesspet » 10 Sep 2013, 00:54
Hello!
Is there a chance to get an info when this bugfix release is available. I also stuck with this problem. :P
Setup: Win 7 - 64 - running Usine 32 - Möbius 2.2 after Update same Problem with 2.5
I've tried to use OSC to control Mobius and I've also a strange effect.
Sending OSC from Usine to Standalone Moebius - WORKS
Sending OSC from Usine to VST Moebius - Does not work.
This was the last chance to find a solution. This is one of my core usages. Plan was to use this during a workshop in 12 days. So it looks that I must cancel this. ;)
La Tenaille
Unread post by La Tenaille » 10 Sep 2013, 11:29
It works with v11 :)
martignasse
Unread post by martignasse » 10 Sep 2013, 11:55
yep, corrected in v11,
*Plug-ins effects (not identified as instruments) wasn’t receiving midi events
hesspet wrote:Is there a chance to get an info when this bugfix release is available. I also stuck with this problem. tongue
the best way to be informed promptly is to fill a bug report ;)
hesspet
Unread post by hesspet » 10 Sep 2013, 14:52
Martin, I struggled over this last night.... reallity was faster :-)
BTW: THANKS TO ALL DEVELOPERS FOR THEIR GREAT WORK!
La Tenaille
Unread post by La Tenaille » 12 Sep 2013, 16:22
it seems Mobius can't send MIDI out ? I have a script that sends MIDI notes from Mobius VST to a controller, and it doesn't work anymore.
Unread post by nay-seven » 13 Sep 2013, 08:34
not easy to help with specific scripts, any basic script with midi out to test ..? any chance to test this in an other free Daw to be sure the script is ok..? ( Cantabile lite for example..)
La Tenaille
Unread post by La Tenaille » 14 Sep 2013, 13:33
Hi Nay,
I've made some other tests and it seems to work on my home laptop. I'll make more tests on my DAW next week.
To send MIDI from Mobius you can use the timing clock instead of a script : track to be recorded set to sync=out, and a device out set in the midi devices menu.
The weird thing with Mobius is it can't send MIDI to the host, only to the device itself : you need to deactivate the corresponding host device out. Jeff says it's to avoid decays. So I use MIDI Yoke and it works fine :)
La Tenaille
Unread post by La Tenaille » 22 Sep 2013, 21:14
ok. It works now after struggling with my MIDI configuration :)
Unread post by nay-seven » 23 Sep 2013, 08:27
good news !
Users browsing this forum: No registered users and 114 guests
