hello
i notice a drift when feeding midi clock into hollyhook or usine 5 from reason 7.
after a short while they are out of sync.
what can i do about this?
mark
midi clock drift
try to reduce the BLOC size in the setup (ie 64)
funkyguitarist
hello senso
thank you for your quick response.
the bloc size was not the problem.
i change the frame rate of the mc receive module to 30 instead of the default value of 24.
it seems that reason 7 is sending 30frames.
didn t even know that a midi clock has a frame rate. i thought it was only important with MTC to pick the right framerate,
but thanx anyway
now its working
mark
but thanx anyway
now its working
mark
I'll investigate.
Any more response regarding the MIDI Sync Drift issue. Currently Using Traktor feeding Midi Beat Clock and seeing drifting as well. Looking into SMTPE/MTC and beatclock sync possibilities and found this.
I will look into the Frame rate issue as well and see if I can duplicate, or have any success changing although only using Beat Clock at the moment.
Users browsing this forum: No registered users and 86 guests
