midi clock drift
funkyguitarist
Unread post by funkyguitarist » 21 Aug 2013, 21:58
hello
i notice a drift when feeding midi clock into hollyhook or usine 5 from reason 7.
after a short while they are out of sync.
what can i do about this?
mark
Unread post by senso » 22 Aug 2013, 08:40
try to reduce the BLOC size in the setup (ie 64)
funkyguitarist
Unread post by funkyguitarist » 22 Aug 2013, 11:53
hello senso
thank you for your quick response.
the bloc size was not the problem.
i change the frame rate of the mc receive module to 30 instead of the default value of 24.
it seems that reason 7 is sending 30frames.
didn t even know that a midi clock has a frame rate. i thought it was only important with MTC to pick the right framerate,
but thanx anyway
now its working
mark
Unread post by senso » 22 Aug 2013, 12:09
I'll investigate.
sephult
Unread post by sephult » 09 Oct 2014, 13:11
Any more response regarding the MIDI Sync Drift issue. Currently Using Traktor feeding Midi Beat Clock and seeing drifting as well. Looking into SMTPE/MTC and beatclock sync possibilities and found this.
I will look into the Frame rate issue as well and see if I can duplicate, or have any success changing although only using Beat Clock at the moment.
Users browsing this forum: No registered users and 80 guests
