Usine Hollyhock Update #6 (1.02.010) is available for download
Announcements
Unread post by senso » 10 Aug 2013, 18:45
[large]Usine Hollyhock Update 6 (version 1.02.010)[/large]
Can be downloaded in the download area.
- Most of reported issues fixed.
see the release notes for more information
To upgrade just copy the content of your old /Config folder within the MacOSX packet or the WIN directory.
seamus
Unread post by seamus » 11 Aug 2013, 11:53
Unfortunately this update did not fix my nvidia issue.
I heard that installing older versions of direct 9 can help even if direct x 11 is installed.
When I see you senso maybe u will have some idea.
ceasless
Unread post by ceasless » 13 Aug 2013, 14:05
This update fixed the performance issues I was experiencing on my (quite underpowered) laptop! Now the patch I've been working on runs stable, though there are still some CPU spikes and audio glitches. But at least the BPMs aren't flying around and all the seq-switches are running in time.
Thanks!
seamus
Unread post by seamus » 29 Aug 2013, 14:59
Windows 8 seems more tricky to get dpc spikes down. I have some random spikes sometimes from the system that i didnt before in windows 7.
Also I find running HH without my graphics nvidia card is more spikey. It seems if you have a good graphics card it is best to use it.
I will eventually make a post for all the optimization for windows 8 I did.
Users browsing this forum: No registered users and 307 guests
