Usine Hollyhock Update #5 beta (1.02.008) is available for download
Announcements
Unread post by senso » 20 Jul 2013, 18:48
[large]Usine Hollyhock Update 5 (version 1.02.008)[/large]
Major release.
Can be downloaded in the download area.
The free version is also available.
Improved performances, new audio engine, new script 10x faster.
improvements
- new fast script module up to 10x faster see Fastscript Compatibility notes.
- improved performances, optimized audio engine.
- SysEx implemented.
- NO AUDIO mode implemented to run Usine without sound card.
- new HID Device module.
- many other improvements.
- most of reported issues fixed.
- Send to MIDI LAN option can be set individually for each MIDI device.
see the release notes for more information
how to upgrade
To upgrade just copy the content of your old /Config folder within the MacOSX packet or the WIN directory.
Then, rescan your plug-ins.
Thomas Helzle
Unread post by Thomas Helzle » 20 Jul 2013, 19:40
Thank you!
Cheers,
Tom
sephult
Unread post by sephult » 20 Jul 2013, 20:29
Woohoo...Thank You!!! Much appreciated and great timing :)
seamus
Unread post by seamus » 20 Jul 2013, 21:28
I am away from my computer. Is the graphics issue solved?
seamus
Unread post by seamus » 21 Jul 2013, 01:30
damn I still have the massive graphics flickering! Graphics don't behave right.
Some kind of direct x 11 windows 8 issue. Anyone else having it also?
I hope im not alone. I guess I will file a bug report.
iococoi
Unread post by iococoi » 21 Jul 2013, 10:18
hi seamus!
what drivers are you currently using? did you try the latest beta ones from nvidia?
GeForce 326.19 Beta for win 8 64 bit
http://www.geforce.com/drivers/results/64412
Unread post by 23fx23 » 21 Jul 2013, 13:11
:cool: thx olivier
seamus
Unread post by seamus » 22 Jul 2013, 08:49
Icocoi! You had the right answer!! That driver fixed everything! Wow.
What a relief. I have to say a big thanks to you and the Usine community. Now I can get back to patching and designing.
S
Unread post by nay-seven » 22 Jul 2013, 09:10
Great, welcome back to patching , and good news for you ( and us)
joffo78
Unread post by joffo78 » 22 Jul 2013, 09:37
It's seems to be a very cool update form me !
The cpu usage seems to be very optimized.
i look forward to test it .
Thanks for your job
iococoi
Unread post by iococoi » 22 Jul 2013, 09:50
hi seamus! not at all..glad to be of help. it's always a good idea, to get hold of those beta ones..
multiphone
Unread post by multiphone » 24 Jul 2013, 11:47
Thanks a lot for this new version...
HB
Lines / Points / Squares
http://www.hervebirolini.com/
