[Scripting] HollyHock 1.01.007d
sephult
Unread post by sephult » 29 Jun 2013, 15:05
Started working with learning the scripting interface as I am having other issues with HollyHock that is preventing me from moving further.
I was curious if the scripts were working properly in HollyHock (Noticed Wiki Disclaimer) or if I was not doing something right in the following basic script:
Summary: Creating an output to feed a text field, set a string and the output to 'Empty'
// Script example
// Paramters declaration
var output: Tparameter;
var dataread: String;
// initialisation procedure
procedure init;
begin
output := CreateParam('output',ptTextField );
SetIsInput(output,false);
end;
// Global Variables
// Main Loop procedure
Procedure Process;
begin
SetStringValue(dataread, 'Empty');
setvalue(output,dataread);
end;
I then tie a text field to the output, however I cannot get the output of the script to push 'Empty' to the text field.
Any advice?
-S
Unread post by bsork » 30 Jun 2013, 20:40
Hi, SetValue is for numbers, while SetStringValue is for strings...
This example works:
Code: Select all
begin
 dataread := 'Empty';
 SetStringValue(output,dataread);
end;
sephult
Unread post by sephult » 02 Jul 2013, 01:19
Thanks a ton bsork!
I finally got to verify and now back on track, much appreciated!
-S
Users browsing this forum: No registered users and 100 guests
