New version (3.20 beta1) Major Update
Improvements
New Asio engine solves many sound card compatibility problems.
New intern memory allocation, more efficient, compact and faster.
New Shift Array module.
New precision option in user curves (sequencer)
New SDK, improves the User Modules development features
fixed bugs
Compatibility problems with Ohmforce plugins.
The “Clear List” button in the sampler, sometime crashes Usine.
The Knob module is now stored in the conductor.
Grain module initialization problem.
Small display bug in with EnergyXT2 plugin.
Compatibility notes
Some User Modules (Draw Trajectory and Display Number) aren’t compatible any more; But new versions are now included in the Usine package (User section of the Modules Browser)
fixed bugs
Compatibility notes
martignasse
hi senso,
Great work, i just tested it and it look pretty stable.
The only thing i have to say is "where is the c++ SDK"
but i know, it's just a beta.
keep up the good work
Sorry the C++ SDK isn't finalized yet.
soon
soon
yeah thanks for the new version !
k
k
yeah ! thanks Senso !
just one thing...: i really hate this white background for the browser and this yellow dirs , ha ha..
a color suggestion here : http://yanledean.club.fr/test/browser.gif
and tell stop me if i borrow you with my suggestions...
They are only standard Windows colors!
If you send send me other folder icons I can change easily.
ok boss !
About the "compatibility problems with OhmForce plug-ins" fix... Does that mean they are not supported anymore? Because My Ohmicide plug-in which was working fine in 3.05b is now scanned as invalid...
oups!!!!
you're right. I'll post an update tonight.
I'm sorry.
I'm sorry.
Users browsing this forum: No registered users and 359 guests
