What to use for PSingle?
Unread post by woodslanding » 12 Jun 2013, 16:47
I have a script based on the simple audio example script from v5. But it requires some values of type PSingle.
V6 does not recognize this type. What do I use instead? There are no audio example scripts that I can see in the new browser....
Unread post by bsork » 12 Jun 2013, 22:42
PSingle is a pointer type, and to me it seems that pointer types aren't allowed in the new version (so far?). Using ^Single instead of the predefined PSingle type didn't help. GetDataPointer() is also missing.
Here's an attempt at doing the old audio example in a different way:
Code: Select all
// Audio Volume
// Simple Audio Volume Script
// parameters declaration
var input    : Tparameter;
var output   : Tparameter;
var gain     : TParameter;
procedure init;
begin
 Input := CreateParam('In',ptaudio);
 output := CreateParam('out',ptaudio);
 gain := CreateParam('gain',ptDataFader);
 SetIsOutPut(Input,false);
 SetIsOutPut(Gain,false);
 SetIsInPut(Output,false);
 SetMin(gain,0);
 SetMax(gain,1);
 Setvalue(gain,1);
 SetLength(output,BLOCSIZE);
end;
// Global variables
var i            : integer;
//var pin,pout : PSingle;
var g : single;
// main proc
procedure Process;
begin
 //pIn := GetdataPointer(0);
 //pOut := GetdataPointer(1);
 g := GetValue(2);
 for i := 0 to BLOCSIZE-1
 do begin
   //pout^:= pin^*g;
   //incptr(pin);
   //incptr(pout)
    SetDataArrayValue(1, i, GetDataArrayValue(0, i)*g);
 end;
end;
This works, but uses a lot CPU.
I tried the same in V5, and there both versions of the script worked, and both used negligible CPU.
Unread post by senso » 12 Jun 2013, 22:54
Because of the cross platform implementation (WIN,OSX,64) we use a new script engine which is less CPU friendly.
That's why the the V5 script-pointers capabilities are not available in Hollyhock.
No solution actually except rewrite a new script engine and it could take years...
But we made a particular effort to simplify the SDK. A user module is a very good option for intensive data manipulations?
Unread post by woodslanding » 13 Jun 2013, 08:32
Okay, that's good to know. I'll lay off the scripts. And I'll look into the SDK.
But for now, I realized my script doesn't need to work in the audio path anyway, it can just create a control signal for a volume module.
But I may just use modules anyway if the script engine is not cpu friendly. I mostly did it to save CPU!
cheers,
-e
Unread post by woodslanding » 13 Jun 2013, 08:52
Wow, no joke!
A simple midi change channel script takes ..33% on my quad-core i7!
16 of those, that's 5% CPU just to change midi channels.
Seems like a set of basic midi tools would be a good use for the SDK. Or nice to have as basic modules....
I'll see if it's cheaper to convert to and from midi using modules.
EDIT: that brings it down by about half. Guess that's the better choice.
Unread post by 23fx23 » 13 Jun 2013, 14:42
,;:, damned macs^^ :p
seamus
Unread post by seamus » 14 Jun 2013, 12:01
I replaced some midi scripts with the midi transformer and my patch became 50% more efficient.
Thanks for the tip!
Unread post by senso » 14 Jun 2013, 13:26
check also the Midi multi-filter
Unread post by senso » 14 Jun 2013, 13:28
slowly I'll replace all midi scripts by modules which are 100x faster
seamus
Unread post by seamus » 14 Jun 2013, 15:24
Thanks senso!
Users browsing this forum: Bing [Bot] and 12 guests
