CC switch ?
kara
Unread post by kara » 10 Sep 2007, 17:04
I've just paid a license for Usine, so I hope I'll become a premium memeber soon here :)
Would it be difficult to build a 4 position switch that switches in function from a CC range received
example:
0-32 : position 1
33-64 : position 2
65-96 : position 3
96-128 : position 4
tia
k
kara
Unread post by kara » 10 Sep 2007, 17:31
Looks a bit stupid to answer my own post :/
It seems that a combination of a Mapper value & a selector could do this
Right ?
k
Unread post by senso » 10 Sep 2007, 19:03
kara wrote:Looks a bit stupid to answer my own post
No, it means that you're not only waiting for someone to give you the answer, but still searching yourself! cool!
I'm not sure I understand what you really need. Could you explain a little more precisely?
kara
Unread post by kara » 10 Sep 2007, 19:34
ok here is what I what
- I have a midi in
- the midi stream has to go to a swith with one midi in and 4 midi out
- to the four midi out will be connected a vsti to each out
now depending on the CC received the swich sends to midi stream to one of the vsti's
CC 0 - 32 : to vsti 1
CC 33- 64 ; to vsti 2
tia
k
Unread post by senso » 10 Sep 2007, 20:14
The best way is to deal with flows.
You need 4x the Modules/Event Control/pass Event Flow
and test the range of the CC with Modules/math/logical:
A>B
A<=B
A and B
some thing like
if A>0 and A<=32 then pass the Midi flow.
repeated 4x
Also, probably a Midi Filter module to process test only on CC.
To go faster, create a Sub Patch that you repeat 4x...
kara
Unread post by kara » 10 Sep 2007, 20:25
thanks Olivier
hmm... only that the CC would only be send by the master keyboard if i want tochange the routing and not with every note. If I want to keep the routing I would need some kind of a switch too that keeps the state of the last received CC
no ?
k
Unread post by senso » 10 Sep 2007, 21:26
just after the midi input, and before the midi filter you can and a [stop event flow] module connected to a switch to activate the the CC dispatch?
kara
Unread post by kara » 10 Sep 2007, 21:33
thanks, gonna work on this
k
