Problems with audio levels
waverider
Unread post by waverider » 10 Sep 2007, 14:04
in the first time trying out usine, I followed the quick start -I did the audio thru example.
it works, as I get audio thru, but the levels of input-output do not match. For any level going in (like 0db), the output is much lower.
Is that a known problem? Or a specific problem with my setup? Cause it makes mixing real difficult if a 0db track does not equal 0db in the master section...
Thanks for responding....
Unread post by bsork » 10 Sep 2007, 14:31
Have you checked the master output level? It defaults to -6 dB.
waverider
Unread post by waverider » 10 Sep 2007, 18:07
sorry I am new to usine but what i mean is that usine does not seem to have unity gain, meaning that a track entering at 0db at the inputs will output at a much lower volume even if the master out fader is set at zero
unity gain is 0db = 0db out
when I try it with all faders at zero it outputs something along -10 or -12 db. (with a 0db signal entering at the input)
the same setup in ableton live of course if you input 0db in you will get 0 db out....
so my question is usine has unity gain or is there something I don't get?
thanks
Unread post by senso » 10 Sep 2007, 18:40
Normally, Usine has a unity gain.
Just tested on my system with a calibration CD
CD 0bB
-> master IN vu meter 0dB
-> track IN gain fader at 0dB
-> track IN vu meter at 0dB
-> track OUT gain fader at 0dB
-> track OUT vu meter at 0dB
-> master OUT gain fader at 0dB
-> master OUT vu meter 0dB
everything seems OK
It should work like that,
If not, which vu meter isn't at 0dB?
waverider
Unread post by waverider » 10 Sep 2007, 19:01
the master out modulates a lot lower than it should on my system. again I am a newbie, but it is pretty easy to set all faders at 0.
So I will have to look further and check another time to be sure if all this is correct:
and will come back later...
merci Olivier
j'espère expérimenter plus avec usine ce logiciel semble extrèmement intéressant, peut-être je pourrai dépasser les limites de ableton :)
alors à bientôt...
bmoussay
Unread post by bmoussay » 10 Sep 2007, 19:36
Hi waverider,
Have you checked that the input trim level (top of the rack) is set to 0db. This can seem dummy but I've actually already had the problem.
Rgds,
B.
Users browsing this forum: No registered users and 56 guests
