rec fader movment with sampler
It works if you put a smoother between the fader and the input.
yep or alternatively put a set array size of buffer size after the fader to convert the single to array
iim made mistake, can work but think it's better to use 'fill array' of buffer size
the usine buffer size setting (32-64-128- ect) found in setup, but there is also a module for that, don't remembver if in math or somewhere else, or just clic on an audio wire and you will see the size
Users browsing this forum: No registered users and 40 guests
