how to ignore zero values
seamus
Unread post by seamus » 17 Mar 2013, 10:25
I have several buttons feeding into a memory recall inlet. The buttons can be configured to output different number values. I only want to use the "on" value of the button. I have tried clicking on "null event if off" but the buttons are still toggling between a zero value and the "on" value. if i hit a button that triggers a 2 i dont want it to trigger a zero. HOw can I achieve this?
Unread post by nay-seven » 17 Mar 2013, 10:44
I don't know what you mean by "memory recall inlet." but the nul event if off option works for this , for example on a fader or a preset manager..?
seamus
Unread post by seamus » 17 Mar 2013, 10:47
i will upload an example
seamus
Unread post by seamus » 17 Mar 2013, 10:54
http://www.sensomusic.com/forums/upload ... ductor.pat
in this example the buttons toggle between a value of 2, 3,4 and 0. I want the zeros ignored. When i click a 12 step button i dont want a zero value sent.
seamus
Unread post by seamus » 17 Mar 2013, 11:23
it seems as if the null event if off is not working... is there another way to ignore the zero values?
Unread post by nay-seven » 17 Mar 2013, 11:25
i spend a moment to understand, but many of the buttons in you patch are not set to "nul event if off" ?
once done , works here...
seamus
Unread post by seamus » 17 Mar 2013, 11:29
ah ok the problem was i was testing with just the first couple of buttons. They all have to be set to null event if off in order for them to all work!.. thanks NAY you helped out so quickly!!
Unread post by 23fx23 » 17 Mar 2013, 15:28
thats the simple wa with buttons, otherwise in other cases you can use 'stop if equal 0' or 'pass if different than 0' using pass/stop event modules and logical
seamus
Unread post by seamus » 17 Mar 2013, 20:57
I love usine! I'm sure will really love
hollyhock!
Unread post by 23fx23 » 18 Mar 2013, 13:54
:) we al love usine^^
