dynamic List box
noise2sine
Unread post by noise2sine » 31 Jan 2013, 09:03
I wanted to know how i can make list box dynamic ? I'm using a vst instrument and my wish is that when i create or rename a preset with the VST instrument ,it would be autamoticly updated in the list box ?
Unread post by nay-seven » 31 Jan 2013, 09:26
Here the IML solution, be sure to rename your VST and the list box the same way ( or change them in the Usine message box too)
once you have change a name or add a new preset the listbox will be updated ( when you change of preset)
Download
noise2sine
Unread post by noise2sine » 31 Jan 2013, 12:09
Hello Nay,
Unfortunatly i couldn't make it work :(
I have used yr patch but i had to delete yr vst plug in because i don't have it. So i have replaced it with a new vsti and created a new list box.
I have right clicked on the vsti for renaming it and same for the list box.
I can see the preset names in the list box but if i'm changing a preset name, the new name won't appear in the list box.
What am i doing wrong ?
Unread post by nay-seven » 31 Jan 2013, 12:23
yes, sorry for the VST
the has changed module must be connected to the array outlet.., maybe you don't see it with the missing VST
what is the VST you use..?
And remember the new name will appear only the next time you change of preset in the listbox ( when refresh)
Unread post by nay-seven » 31 Jan 2013, 14:07
Works here..?
i rename a preset in the VST, change of preset in the list box= the new name appears
Download
noise2sine
Unread post by noise2sine » 01 Feb 2013, 15:03
Thank you Nay, working perfectly !
noise2sine
Unread post by noise2sine » 11 Feb 2013, 09:31
Hello Nay,
I'm using a Reaktor instrument with your patch and it's working fine : i can create and rename a preset in reaktor and then it appears in Usine list box . If i'm clicking on names in the Usine list box i can see the preset moving in Reaktor.
The problem i'm facing now is that when i'm using the conductor, the different preset in Usine list box change but it has not effect in Reaktor !!! Like the list box doesn't transfer anything to Reaktor while using the conductor ?
What's wrong ?
Unread post by nay-seven » 11 Feb 2013, 10:38
I made a quick test with several ensembles, works here ?
which ensemble do you use ( if it's a public one) ?
noise2sine
Unread post by noise2sine » 11 Feb 2013, 10:51
I'm using the Metaphysical Function but i have inserted a tuner in the patch. Maybe it's the reason why i get those problems. I will try without it and let you know
Users browsing this forum: No registered users and 89 guests
