How to add a midi note OFF , and set a variable for it ?
Taysete_DJ
Unread post by Taysete_DJ » 26 Jan 2013, 13:26
Hello Usiners,
I have a problem with some panels and workspaces , i want to make a midi sequencer , im going good ...
but the problem is , when i send the midi notes , it just send NOTE ON messages , i have triyed many modules and all are more or less the same , SO when i send the midi it just send all notes with a continue pression , i want to make a fader or something to controll the note pression ; (see the problem in the image)
Here im just testing with lazysnake sequencer to have a example , im building a sequencer learning from this sequencer , but the main problem is to add a specific note pression ...
If its possible to make it in a fader that would be cool
Unread post by nay-seven » 26 Jan 2013, 14:18
here an example , i suppose pression=velocity..?
Download
Taysete_DJ
Unread post by Taysete_DJ » 26 Jan 2013, 14:44
nay-seven wrote:here an example , i suppose pression=velocity..?
Download
OH yes , thats it , works perfect thank you so much nay!
Regards
Taysete_DJ
Unread post by Taysete_DJ » 26 Jan 2013, 16:30
And how i can edit direction of the sequencer ? by random just goes from left to right
i want to make reversed direction and if is possible backward+forward loop
By the way the sequencer is looking good
Thank you for all the help :D and yea usine is addicting
Unread post by nay-seven » 26 Jan 2013, 17:22
No reverse function but you play with array
here a forward.reverse version, when OFF you can use 3 modes , roll need you move the knob
Download
Taysete_DJ
Unread post by Taysete_DJ » 26 Jan 2013, 17:27
nay-seven wrote:No reverse function but you play with array
Download
thank you again :D you are the faster answering
Taysete_DJ
Unread post by Taysete_DJ » 26 Jan 2013, 17:43
Download
oh well that makes a similiar function , but i dont mean this , sorry maybe i explained bad,
I mean the bar of the sequence , i want to do like in sequenaya some direction buttons for the main sequence process
In sequenaya goes to right and left , my sequencer just goes to left
i want to make 3 modes if possible
From left to right (Normal mode)
From right to left (Reversed)
Left to right and right to left (Loop mode) Like in Blip 1000 and 2000 VSt ( in this mode is like to duplicate the size of the sequence)
Like you see here :
Unread post by nay-seven » 26 Jan 2013, 18:13
so you have to copy a part of the sequenaya, then use the same system with the toggle to alternate..?
Download
Taysete_DJ
Unread post by Taysete_DJ » 26 Jan 2013, 18:20
nay-seven wrote:so you have to copy a part of the sequenaya, then use the same system with the toggle to alternate..?
Download
allrite , so then is not possible to make a loop to jump left to right .. ok then , well anyway changing between reversed and forward will be enought to do that
Thank you so so much nay , and sorry for make you work hehe
Regards
Taysete_DJ
Unread post by Taysete_DJ » 27 Jan 2013, 00:23
Hmm , i feel so bad asking you help again , but i cant do it ,,,
I have tryied changing parameters because the step limiter is set to 16 steps and i want to have a control to swap between 8 steps to 64 steps maxium..
also if i connect the step data inlet to the advanced counter , doesent respond to the main sequencer
If you can solve this last problem, my sequencer will be finished , and i will not spam you no more with so many questions :P
heehhe
Thank you very much :D im near to have this project finished
here is the .pat : download
Unread post by nay-seven » 27 Jan 2013, 10:46
yes, was not logic, cause you want to use the counter but your all your steps was drive by an other synchro patch...
this method can't keep the old advanced counter, so I've simplify this one with only a reverse button
Download
btw, still curious to know the Usine version you use..mm
Taysete_DJ
Unread post by Taysete_DJ » 27 Jan 2013, 13:19
I have 3 versions , 2 free demo version (one old and the new one) and a friend giveme his old version in a dvd with samples and extras, i use the new demo and his other version to work with...
I think i must delete the old demo... xD
hey man , this is working perfectly :D thank you very very much nay !
Users browsing this forum: No registered users and 136 guests
