kind of a pitch shifter
percuson
Unread post by percuson » 21 Dec 2012, 15:28
On the web I found a video how to build a pitch shifter in Max/MSP
pitch shifting in Max
I tried to rebuild this in usine...
download:pitch shift delay
I also added a feedback, which results in strange sound effects.
The tempo sync button is not really a tempo sync. It only sets the delay time to the selected time period. But it helps to get something like a sync.
It's not finished yet, but maybe you can test it and give me some feedback.
Merry Christmas!!!
joffo78
Unread post by joffo78 » 21 Dec 2012, 18:16
good job i didn't manage to do that ! i'll look how did you do...
thank to share
percuson
Unread post by percuson » 21 Dec 2012, 19:50
thanks a lot :) !
Check it out. I tried to make it the most simple way... It should be no problem to get how it works.
It took some time to find out which ramp type is needed (down for tronsposing up and up for transposing down) and how to calculate the pitch. Have a look at control sub-patch to see how I did it.
The pitch delay sub-patch is the heart of the patch. Don't wonder abaout the ramp in the main patch. It is only there, because I had some trouble synchronizing both delays without any noise. It only gives the start signal for the ramps inside the sub-patch.
If you have questions, don't hesitate to ask.
waolelaid
Unread post by waolelaid » 21 Dec 2012, 21:19
Thank percusson just test it work very fine and
i looked into the subpatch really clever learning a lot
congrat :D
Friedrich Nietzsche
percuson
Unread post by percuson » 31 Dec 2012, 04:08
I uploaded a new version.
It's a bit cleaned up and simplified.
Have fun!
Download here: pitch shift delay
waolelaid
Unread post by waolelaid » 01 Jan 2013, 00:51
thank to share and the best just for the new year
work well :D
Friedrich Nietzsche
