trig when pos meet marker
- nay-seven
something like this..?
r.erorr
and also this . . .
http://www.sensomusic.com/forums/upload ... arkers.pat
joffo78
e.erorr i didn't notice but in this way it work only if the marker are read in the correct order. How can i do to have the number of the marker
active in all circonstances ? and i can't have the number of the marker.
anyway, i want to find a solution to have a trig each time a value correspond at one of the value contains in an array and the number position of this element.
r.erorr
Joffo78 what do you mean with "correct order"? Yes, it works only with "auto sort markers" option, that is 1,2,3,4,5,6 etc.
if you want random positions like 6,3,7,9,2,6,3,5 it will become more heavy.
r.erorr
Aaa . . you want to add markers at predefined order or sample position.
Nice, if this is solution
- nay-seven
yes, maybe the difficulties is to have an efficient comparison between number with digits...?
- nay-seven
Numbers that have some decimal ? 1,38 for example
r.erorr
Hi, joffo78, can i ask what we gain from adding and removing markers in realtime? because, if the markers positions are previously defined, I can't see essential difference between presence and absence. You can easy include or exclude markers from playback.
If you want visual feedback only from active markers maybe try to experiment with colors: SET_LAYOUT 'markers color' and 'markers font color' ?
joffo78
hello
i managed to do that :
trig marker
i have 2 problems :
1 because the necessary round operation the trig is imprecise.
2 i found an empiric solution to detect the number of marker, it work except the last marker. Why ?
trig marker
i have 2 problems :
