suggestions
franck
Unread post by franck » 31 Jul 2007, 15:47
Hello, this is my first post excuse my poor english ( french men).
I download the demo and very happy to use this soft. I have bought usine today, tomorrow the key and gold member.
I have some suggestion, (I precise I'm working just in SEQUENCER MODE, so all remarks are for SEQUENCER use).
1: possibility to move order tracks, up/down
2: able to select all contents of one patch (select all) for copy and paste to another patch.
3: a delete active track button
4: a button to return to the start of song (or first marker) with current readind position to the first marker or first patch
5: BUG I think : When I delete a patch and I do undo command the patch is come back but it is empty ?
6: When creating marker near the begenning or the end of patch it will be interesting if new marker position is at the end or the begenning near patch in the time line ( if Object is selected in the ruler , OBJECT,grid,none).
7: When I create SeqWave patch, if I change the output L R to SendBus the Volume Curve has not effect to the sound, so bad.
8: A litle b utton in the track name (like ON button in insert patch) to mask the mixer output of the select track. If I have more than 8 tracks I would like to choose which tracks I can see ( tracks I often use).
Thank you and long life USINE
franck
franck
Unread post by franck » 31 Jul 2007, 16:49
Excuse me for the suggestion number 4, it is already possible with HOME key.
franck
Unread post by senso » 31 Jul 2007, 19:03
thanks for your feedbacks.
Don't worry about your English. Shakespear doesn't come often on the forum...
English spoken users are probably very proud we use this language?
yes, I know that I have to do that,
Yes easy, Hope soon
same than point 1!
I'll take look.
6: When creating marker near the beginning or the end of patch it will be interesting if new marker position is at the end or the begenning near patch in the time line ( if Object is selected in the ruler , OBJECT,grid,none).
yes, stop!!!! I need to sleep!!!!
it's normal, because the curve level is the level of the entire patch.
You can add a userCurve/volume + Volume module to apply the curve before sending the sound to your buses?
8: A litle button in the track name (like ON button in insert patch) to mask the mixer output of the select track. If I have more than 8 tracks I would like to choose which tracks I can see (tracks I often use).
Yes, also a way to reduce the width of unwanted tracks.
