enabling 1 vst while disabling all others...
Bovo
Unread post by Bovo » 23 Oct 2012, 06:12
howdy!
let's say I have 3 vsts loaded and I want to use only one at a time and disable all others, at the push of a single button on my midi controller.
here's how it would work:
I have 3 buttons assigned, when i push the first, I want only the 1st plugin to be enabled while the 2 others are being disabled
when I push the 2nd button, I want the 2nd plugin to be enabled while the 2 others are disabled... so on so forth...
I'm trying to figure it out right now... your input will be appreciated!
joffo78
Unread post by joffo78 » 23 Oct 2012, 08:10
hello try this : 3 vst
i use 3 vst so you'll have to replace there.
gurulogic
Unread post by gurulogic » 23 Oct 2012, 09:18
There are often many ways to achieve the same goals in Usine but you coud also try this simple solution.
edit: I suppose it would make more sense to not enable the "at least one" function on the group switches so that all FX can be off at some time.
Unread post by nay-seven » 23 Oct 2012, 09:28
And an other way here :-)
i use track 1 as source :
Edit the list box as
VST 1 =1
VST 2 =2
VST 3 =3
Users browsing this forum: No registered users and 62 guests
