Piano Rolls and Synchro in Ableton Live
noise2sine
yes, you can put the piano roll in sync = button
then a button with data buses..?
or each one a button but with the same midi learn
or use the starting outlet of the first piano roll to send the play to the second
and certainly others ways
noise2sine
The second solution is working fine for me. But i was thinking about a way to have in the same workspace the possiblity to send midi output from two different piano roll ,and with Usine used as a VSTi in Ableton Live ? my wish is to record these two piano roll in two different track in Live.
I can't configure midi output from Usine because it is used as a VSTi and if i'm using to different instance of Usine, i'm losing the sync process described above ...
Any solution ?
Any solution ?
Use 2 différent Midi Canal..?
noise2sine
I do , but i can't get the two different midi channel in Live ! How can i make that ?
yes, I've try and ableton is not easy about midi routing and can't find a quick way, i suppose you need to find a midi mapper tool to filter each canal and distribute them to 2 different tracks.
we have protofuse here on the forum who is a certified ableton guy, I'll ask him...
hi there,
Live constrains us to have only one midi channel per track.
It also drives us to tweak things a bit when you need midi from a track where there is already an instrument (= a midi consumer)
You have to use source routing in that case.
Let's say that:
track 1 the midi clip and your instrument
track 2 the track where you want to grab midi from the track 1
both midi tracks of course
you have to choose in the track two as a midi source the track 1 and, in order to switch the input of track 1 to be processed, you have to put the monitor forced on IN .
does it answer ?
Let's say that:
does it answer ?
julien
julienbayle.net
designthmedia.com
soundcloud.com/protofuse
_ _ _ _ _ _ _ _ _ _ _ _ _
Ableton Certified Trainer
julienbayle.net
designthmedia.com
noise2sine
Hello protofuse,
I think what you describe is what i'm doing at the moment in Live :
- One midi track with Usine (the Usine workspace contains 2 piano roll, one set on channel 1 and the second one on channel 2)
- another midi track which grab the midi flow from Usine . The problem is i can't set "midi from" Usine and thenchoosing a midi channel from Usine ! Live let pass all midi channel.
My wish is :
- One Midi track with usine
- a Second midi track which grab midi channel 1 from Usine
- a Third Track which grab the midi channel 2 from Usine
Do you think it's possible ?
My wish is :
yes, cause there's only a canal choice when you use a midi interface ( hardware) as input, no when you choose a track
really curious, how Live support for example a midi file with several midi canal inside..?
i've test different way , but i realize Live transform all in canal 1, even if you use different canal as sources ...strange
i suppose we need a midi filter or mapper here, don't know enough Live ...
alternative : 2 use 2 instance of Usine...
noise2sine
To : Protofuse
Do you think Max for Live would allow this ?
Users browsing this forum: Bing [Bot] and 13 guests
