Record in the Piano Roll
mattox
Unread post by mattox » 30 Aug 2012, 07:05
How do I record into the piano roll? I cant seem to figure it out :)
mattox
Unread post by mattox » 30 Aug 2012, 08:35
I think I figured it out :)
Now a few more questions;
1. Say I want to record my vst is there a way for the metronome to click on bar before recording starts?
2. Is there a way for the piano roll to automatically scroll when its playing?
3. How do I move sequences from the piano roll to the sequencer?
I bought Usine a long while back and am only now really getting into it.
Thanks!
Unread post by nay-seven » 30 Aug 2012, 09:31
Welcome back Mattox,
1
there 's a metronome patch in the Usine library, I suppose you've found it, then you can use the quantize record option of the piano roll or create a patch with logic modules and counters to suit your needs?
2
Actually no
3
you can save your sequences as midifiles then drag & drop them directly on the sequencer . Of course if you create complex patch with the piano roll, you can also save the patch and drag & drop it on the sequencer too.
note: for a futur post, prefer the patching forum for this type of questions ;)
Unread post by nay-seven » 30 Aug 2012, 10:58
As it can be useful for others, here an example of a pre-roll recording patch : Download
Users browsing this forum: No registered users and 375 guests
