I would like to give a name to a CC number and then being able to choose among a list different names. Which is the best way according to you to do that ?
Naming CC number
depending of your patch, but here an example of the way to use a combobox for different CC numbers/names :
noise2sine
Thank you Nay , it's working fine . But if i'm using the random CC patch i couldn't find a way to do it ! Any advice ?
Here is an example of where i'm now.
http://www.sensomusic.com/forums/upload ... ontrol.pat
The example is available in the uploader section ( the link doesn't seem to work....)
At the bottom of the patch there's a text input where i can write manually the name of the CC num . my wish is to have a list box with names corresponding to CC numbers.
Thank you
Thank you
i suppose you talk about the Usine patch CC random..?
so same idea, except we don't need anymore the fader:
Users browsing this forum: Bing [Bot] and 19 guests
