too much time patching?
tanabarbier
Unread post by tanabarbier » 25 Jun 2012, 23:06
I just double clicked in a blank part of a windows explorater window to go one level up, does it happen to other people too?
I know it is really stupid, but it made me laugh a lot!
Unread post by nay-seven » 25 Jun 2012, 23:11
ha ha, yes i know that !
same here ;)
Thomas Helzle
Unread post by Thomas Helzle » 08 Aug 2012, 20:31
I can highly recommend XYplorer to replace Windows Explorer -> you can go one level up by double-clicking in empty space besides tons of other good stuff too - give it a try, it replaced WE for me after Vista came with it's rather lame explorer...
It's so much faster to work with.
http://www.xyplorer.com/
Development is very active and support is outstanding :-)
I'm not affiliated but a very happy user,
Cheers,
Tom
Unread post by nay-seven » 09 Aug 2012, 00:27
cool appz !
but, personally i avoid this kind of appz , cause it's really easy to be addict and when you change of Pc or if you have to show something on the pc of someone else, you're lost without it..;)
Thomas Helzle
Unread post by Thomas Helzle » 09 Aug 2012, 14:19
That is true, working with the normal explorer is a pain.
For instance: Opening a folder with 10k mixed files sorted by date takes Windows Explorer 40 seconds here, in XYplorer it's instant
AFAIK XY works from a stick including portable file associations so moving around isn't much of a problem... ;-)
But hey, I was just inspired to post this by tanabiers doubleclick-in-a-blank-space post :-)
Cheers,
Tom
Users browsing this forum: No registered users and 599 guests
