OSCLister
iococoi
Unread post by iococoi » 02 Jun 2012, 11:40
hi all!
can anyone help me on this matter? i was playing around with the OSClister to get some idea, what kind of OSC data Usine is actually receiving from Animata, a lowtech but real-time animation software..so i patched along and suddenly there shows up a rather strange entry in the incoming message values. I checked the URL, which points to some medpub about a web server for clustering and comparing biological sequences..
http://www.ncbi.nlm.nih.gov/pubmed/20053844
...havent got a clue whats that all about..OSC is listening at 7111
~ io
Unread post by nay-seven » 02 Jun 2012, 11:53
you can filter the prefix/adress used by Animata using the substring inlet..?
iococoi
Unread post by iococoi » 02 Jun 2012, 12:08
hi nay
i'm just curious, where that other "thing" is coming from..i did not install this application and comparing biological sequences is just not in my portfolio :]]..
~io
Unread post by nay-seven » 02 Jun 2012, 16:59
can be Animata wich is infected or contain a spy/pub or directly by your Internet connection.
Try to push the button show packets in the global setup/OSC tab, you'll see all incoming data's... ;-) you'll be surprised
iococoi
Unread post by iococoi » 02 Jun 2012, 22:00
so i nailed it down..
after reading through the *Handbook of Usine modules, patch and libraries in pdf ?*-thread, i did some research on the possibilities of getting a pdf out of DokuWiki, which is the wiki engine currently used. i found out about the dw2pdf plugin, which could do that job and had a look at some sites using this plugin. by chance, i landed on the CD-HIT User's Guide, a manual for a protein clustering program..and funny enough every time i generated a pdf from that wiki, the OSClister put out the values mentioned in the first post..that also explains the bioinformatics reference...weird.
case closed!
~io
Users browsing this forum: No registered users and 336 guests
