I'm discovering usine and I just have to say: thanks you !
My suggestions:
2 inserts slots into each mixer. Why? We often need to filter some frequencies or/and apply compression for some tracks especially when we apply some extreme effects.
I'd like to see a "save as vst" function because some usine's patch are absolutely awesome and I would like to use them in my favorite DAW. I'm certainly dreaming...
Great works, thanks you again, and sorry for my bad english.
Moody
Mixer Down "inserts"+ export as vst
Welcome Moody!I'm discovering usine
Yes I plan to do that very soon.2 inserts slots into each mixer. Why? We often need to filter some frequencies or/and apply compression for some tracks especially when we apply some extreme effects.
- insert in the Input section (before the patch)
- insert in the output (after the patch, pre-fader)
You're not dreaming. But I'm still not fixed on the technologie:I'd like to see a "save as vst" function because some usine's patch are absolutely awesome and I would like to use them in my favorite DAW. I'm certainly dreaming...
- VST version of Usine
- Rewire
- New communication protocol.
Hard choice, that we have discussed before.
I need more time to choose the most appropriate.
In my opinion, the VST version should be the priority:senso wrote:You're not dreaming. But I'm still not fixed on the technologie:
- Rewire
VST can be used in any DAW and major DAWs have Rewire compatibility. Rewire means "two programs open" ( let me know if i'm wrong), and I think a lot of user have mono core processor.
Usine as a vst let us used our favorite DAW with Usine AND rewire. Of course, if Usine become a complete professional DAW ( it means a complete midi editor, track recorder, wave sequencer, quick time movie sync for post-production, OMS export, etc...), rewire should be the priority. But I think that usine have to keep in mind it's "live" concept. Qui peut le plus, peut le moins!
I've receive the license key. Thanks you!
You are probably right,
I think that the only interest of the Rewire is the compatibility with Reason.
I'm really not fixed!!!
damstraversaz
in my opinion, the vst version should be the priority. and for bussiness plan too, I thinks that a lot of musicien don't want to change their preferred host but would like to use the power of usine inside
I have many questions!
I'll start a new topic about this subject.
