Mixer Down "inserts"+ export as vst
moody33
Unread post by moody33 » 12 Jul 2007, 00:33
I'm discovering usine and I just have to say: thanks you !
My suggestions:
2 inserts slots into each mixer. Why? We often need to filter some frequencies or/and apply compression for some tracks especially when we apply some extreme effects.
I'd like to see a "save as vst" function because some usine's patch are absolutely awesome and I would like to use them in my favorite DAW. I'm certainly dreaming...
Great works, thanks you again, and sorry for my bad english.
Moody
Unread post by senso » 12 Jul 2007, 08:39
Welcome Moody!
Yes I plan to do that very soon.
- insert in the Input section (before the patch)
- insert in the output (after the patch, pre-fader)
You're not dreaming. But I'm still not fixed on the technologie:
- VST version of Usine
- Rewire
- New communication protocol.
Hard choice, that we have discussed before.
I need more time to choose the most appropriate.
moody33
Unread post by moody33 » 12 Jul 2007, 10:35
senso wrote:You're not dreaming. But I'm still not fixed on the technologie:
- Rewire
In my opinion, the VST version should be the priority:
VST can be used in any DAW and major DAWs have Rewire compatibility. Rewire means "two programs open" ( let me know if i'm wrong), and I think a lot of user have mono core processor.
Usine as a vst let us used our favorite DAW with Usine AND rewire. Of course, if Usine become a complete professional DAW ( it means a complete midi editor, track recorder, wave sequencer, quick time movie sync for post-production, OMS export, etc...), rewire should be the priority. But I think that usine have to keep in mind it's "live" concept. Qui peut le plus, peut le moins!
I've receive the license key. Thanks you!
Unread post by senso » 12 Jul 2007, 11:48
You are probably right,
I think that the only interest of the Rewire is the compatibility with Reason.
I'm really not fixed!!!
damstraversaz
Unread post by damstraversaz » 13 Jul 2007, 08:38
in my opinion, the vst version should be the priority. and for bussiness plan too, I thinks that a lot of musicien don't want to change their preferred host but would like to use the power of usine inside
Unread post by senso » 13 Jul 2007, 08:55
I have many questions!
I'll start a new topic about this subject.
