Hi Guys,
Maybe some of you use the GRM Tools V3. Some of them are multichannel : doppler, delay... The thing is when I import a GRM VST in Usine, the VST always appears with only 2 outputs even if my track has 4 outputs...
For instance, when I do it into Reaper, the number of output of the VST is automatically accorded to the numbers of channel of my track. Any idea ?
Kenan
GRM Tools Multichannel in Usine
Not easy to answer to all situations
for example, you're a Reaktor VST user (8 outputs) but when you insert it in a track, even if your track has 4 outputs
you maybe want use it only on one of the simple stereo outputs..?
so if Usine link it automatically to the 4 outputs, you'll have to delete 2..
( i let you imagine the situation for users like Multiphone who use 8 or even 16 outputs..
multiphone
Hello Ken 29,
As i know, and as i tested...
In PC world the GRM tools v 3.3 ares multichanel in stand alone mode, VST and RTAS but only compatible with Cubase and Nuendo for the moment.
So no way for Reaper and Usine for now.
Best
Best
I called the GRM tools support, they will contact Senso to see how they can solve this. It sounds cool, Olivier always have solutions.
Kenan
Kenan
multiphone
Ok, good news.
wait and see.
Best
wait and see.
Best
