module request: oscillator module
soundmind
Unread post by soundmind » 17 Dec 2010, 02:08
This is a question and a request to any SDK masters in usine land. Would it be possible to create an oscillator user module for synthesis purposes?
thanks.
soundmind
Unread post by soundmind » 19 Dec 2010, 04:43
yes of course. It is a great pack but it is impossible to experiment with different tunings in a polyphonic way or even to play exact frequencies because they only accept MIDI notes. Of course you could tune using pitch bend data but then you are limited to a monophonic sequence. I think usine would greatly benefit from having some native synthesis modules especially when the upcoming major update will have polyphonic capabilities and will allow for this kind of experimentation if I am not mistaken? Anyway, I am just wondering if it is even possible with the SDK?
Unread post by nay-seven » 19 Dec 2010, 09:33
yes, i understand your frustration and i remember caco said he will try to do some osc modules, but as often time is the main problem...
soundmind
Unread post by soundmind » 19 Dec 2010, 21:35
that's cool. I didn't know someone has already considered it. Thanks for the info
caco
Unread post by caco » 20 Dec 2010, 13:41
Yes some modules for synthesis would be a great addition once Usine is polyphonic :)
As always I am limitied by free time for coding but it is on my to do list for the new year along with many other Usine user modules. I have some commercial projects coming to an end soon so hope to get back to Usine after that.
soundmind
Unread post by soundmind » 20 Dec 2010, 20:57
that sounds great! Please take your time. your work is appreciated.
tanabarbier
Unread post by tanabarbier » 16 May 2012, 17:34
Hi everybody!
An oscilator module would be incredible indeed, has anyone some time to work on that? I don't know the first clue about code so I feel totaly useless in here...
So my gift list for this really early christmass would be:
-An oscilator module with various waveforms (sine, sawtooth, square and square with unequal high and low durations, triangle, impulse, noise?)
-inlets for :
-frequency (that would allow to make a vibrato)
-amplitude (0 =>1 ?)
-phase (-x => x ?)
-high/low duration ratio for the square waveform
Would that be really hard to make for a total beginner ? Could someone indicate me a good starting point to learn how to make that kind of things?
Any help would be reaaaaally appreciated!
Thanks !
Unread post by nay-seven » 16 May 2012, 19:36
Glad to see your enthusiasm tana !
yes it's a huge work, specially for a newbie, i suppose first step could be to built some simplest module first to learn sdk ( ( About the SDK)
Then you have to find and learn about synthesis theory ( some Curtis Roads books can be a start ) then coffee, and many sleepless nights :)
tanabarbier
Unread post by tanabarbier » 16 May 2012, 19:44
Yes I know it won't be easy...
On the theory side it's ok, my problem is more understanding how to make it on the computer...
I guess if I find out how to not need to sleep, that would be a start!
Users browsing this forum: No registered users and 131 guests
