Loading sample in the Macro-micro montage patch
noise2sine
If we talk about the same version ( multiphone one based on tanabarbier one) drag & drop works here, but be sure to have 8 grains selected ( each grain correspond to a sampler here)
noise2sine
Still can't make it ! if i drag and drop an audio file to a sampler Usine ask me if i need a wave player for reading the file...
can't load anything even with 8 grains selected
multiphone
Hello Noise2sine,
Can you give me a link to the patch ?
Best
Best
noise2sine
Hello Multiphone,
the patch is in the uploader section ( don't know yet how to make a link)
noise2sine
works correctly here
Are you sure you drag & drop from the Usine browser on the wave display modules..?
noise2sine
no , i was draging from windows explorer !
Working fine now !
Thanks a lot for your attention
Working fine now !
