New ! Synthesis Pack v 2.0
Let's talk about free additional packs
Unread post by nay-seven » 18 Nov 2011, 17:08
New version !
Synthesis pack v2.0 is a pack of patches with plugins inside made with synthmaker and Synthedit .
Some new layouts and some littles modifications for this new version.
on/off button for each patches
midi/drone option for some of them
You’ll find 2 types of patches : Oscillators ( OSC ), some basic vsti synthesizers ( SYN ) and an overview workspace to open all of them at once
more infos
Floego
Unread post by Floego » 18 Nov 2011, 19:19
thanks! :)
CleverConQueso
Unread post by CleverConQueso » 18 Nov 2011, 20:19
Just in time for the Usine Challenge over in the Artistic Zone. The MIDI options makes life easier too. Thanks for doing these, Nay.
-CCQ-
waolelaid
Unread post by waolelaid » 18 Nov 2011, 20:24
hello Nay , thanx too , and just with the last release
a good night in prospect :D
Friedrich Nietzsche
CleverConQueso
Unread post by CleverConQueso » 05 Dec 2011, 19:48
Nay-
Do you mind checking the patch for 'additive'? I think there's something amiss with how the array is routed?
-CCQ-
Unread post by nay-seven » 05 Dec 2011, 20:41
if you mean this, it's normal , i can't find an other way to manage array with this vst...but works fine ..?
CleverConQueso
Unread post by CleverConQueso » 05 Dec 2011, 23:50
Weird - I've got this.
I'll try downloading again.
Thanks.Image
Unread post by nay-seven » 06 Dec 2011, 08:54
be careful to not have an old version of the Dll...?
Unread post by grego mondo » 08 Dec 2011, 13:44
great !!
durkkooistra
Unread post by durkkooistra » 06 Feb 2012, 16:21
cool thanks!
Floego
Unread post by Floego » 12 May 2012, 03:07
Great synths Nay!
I wonder if anyone has tried to create percussive patches with this synths? I mean, electronic snare, kickdrum, hihat, bongos, etc.
could be great to have an usine-only synth drum! :D
Unread post by nay-seven » 12 May 2012, 10:35
Cool idea, i suppose we have most of the tools needed, oscillators,filters, envelope and some effects.
Maybe you can create a new topic and propose a collaborative challenge " create a collaborative synthesis drum set for Usine"
Floego
Unread post by Floego » 13 May 2012, 19:28
yes, a new topic it's a great idea! thanks! :)
tanabarbier
Unread post by tanabarbier » 14 May 2012, 23:27
It is weird, I have the same problem that cleverconqueso with the aditive synth module.
I downloaded it at least 4 times (from the add on section), even tried to open directly the dll only and it is the old one.
Is there something I am doing wrong?
Unread post by nay-seven » 15 May 2012, 00:14
have you try to use windows search with Oscillator additive (Mono).dll..?
you can also let the DLL dir in the same than the patchs in your library
tanabarbier
Unread post by tanabarbier » 15 May 2012, 00:20
Well I tried to put the synthpack in the module/user directory, then in the library, and I also tried to put the DLL folder in the steinberg/VST/ folder... I don't get why it still is the old one...
Something that seems weird to me: The synthpack 2.0 is from 2011, no? Because when I open the .rar and look inside the DLL folder the files dates are all about 2008...
Unread post by nay-seven » 15 May 2012, 08:39
the 2008 and 2009 for spectra and osc3 date are normal, only the patch have been improved.
Once again, you don't need to put them in the user dir or in your vst, just keep the dll dir with the patch, but be sure to delete old ones.
Try this : use a fresh install of Usine, unpack all the synthesis pack and choose this dir as library path in your setup ( don't change anything more) and check if it' work for you .
tanabarbier
Unread post by tanabarbier » 15 May 2012, 18:36
Well I tried as you said: fresh install and unziped files in the library directory, and the same thing that cleverconqueso took in photo with the wrong cabling...
I don't get it...
Unread post by nay-seven » 15 May 2012, 21:51
I've done other test, some strange things occur... so can you test this one download
tanabarbier
Unread post by tanabarbier » 16 May 2012, 04:38
Yeah!
So it is the right one, I only had to re cable betwen the array and the vst, but that's it! Thanks for this patch Nay!
Unread post by nay-seven » 16 May 2012, 08:37
you don't have to rewire, just reload the patch..?
btw, I've updated the pack, this DLL was in the the 1.3 update so i suppose many of us have it in a dir somewhere and i realize Usine (or windows) find it even if it was not with the patch .
sorry for that.
