There is some questions / suggestions regarding how to record User curves in realtime in the sequencer :
- I have not found how to MIDI record several User curves at once (for example for a XY pad)
- also, is it possible to set a specific CC number to each curve ?
- when a curve has a lot of points (100 or more) it becomes very slow to edit them
- how to select several points together (lasso, time selection ?) to move or delete them ?
- when I clear an curve to erase all the points, the name is also erased
- could be the curve drawn during the recording ?
- is there a possibility to record the User curves within the plugin GUIs objects ?
- perhaps that a "fader input" for the User curves will be a possible solution ?
Thanks.
User curves
jean-marc duchenne
hello, thanks for you feedbaks
many interesting points.
In fact I will add a CURVE VALUE inlet and a REC button.
This will solve all your problems!
With the REC + FADER you will be able to do that!
Problem solved now. (next release)
I'll find something
Yes!!!perhaps that a "fader input" for the User curves will be a possible solution ?
Actualy, impossible but with the FADER+REC inlet it will be possible.I have not found how to MIDI record several User curves at once (for example for a XY pad)
For curves recording, usine takes any incomming message. So you cant specify a CC number.also, is it possible to set a specific CC number to each curve
This is caused by a long process in storing UNDO files.when a curve has a lot of points (100 or more) it becomes very slow to edit them
Sorry, no way actually.how to select several points together (lasso, time selection ?) to move or delete them ?
I'll find something
you are right, but I can change this behaviour.when I clear an curve to erase all the points, the name is also erased
normaly it should. If not, it's a bug. I'll take a look.could be the curve drawn during the recording ?
With the REC + FADER you will be able to do that!is there a possibility to record the User curves within the plugin GUIs objects ?
Hey jean-marc, you're becoming a sequencer-master!
vincent michel
composer & novelist
composer & novelist
