Hi did someone alvredy try to make this with usine :shepard
Anyone have an idea to make this ?
Thanks.
make a shepard tones with usine
headphoner
hi,
i tried it few weeks ago without success.
a risset shepard module or script would be cool to use with oscillator or rythm or sample or etc
here a try made with the Osc of the the synthesis pack, can be improved ( smoothing the loop) but the disturbing effect seems here..
Download
Download
Well done nay ! Except when the loop is re-starting i hear a beep sound as you said.
thanks, and yes, it's the the more sensible part, i suppose you'll need some envelope to create smooth and more precise fade
