MIDI note off issue
ahonoe
Unread post by ahonoe » 05 May 2012, 21:29
I'm having a weird issue.
I play a chord into the patch shown below. The Fader correctly registers number of the Note On messages. When I release the chord, sometimes the Fader value doesn't return to zero. Any suggestions as to why? I'm guessing that the MIDI Input terminal is not registering every MIDI note off message.
I've also uploaded the patch here:
MIDI note counter
Regards,
Scott
gurulogic
Unread post by gurulogic » 06 May 2012, 19:53
just a quick thought, you could try a Wait One module after the note off
ahonoe
Unread post by ahonoe » 06 May 2012, 23:17
Thanks guru. I'll try that now and let you know.
Regards,
Scott
ahonoe
Unread post by ahonoe » 06 May 2012, 23:27
No love guru. I even tried inserting 2 Wait BLOCs.
I think I may have an answer though. I gather that not all MIDI controllers transmit Note Off messages. (I remember reading this back in the 80's.) Controllers that don't send Note Offs send Note On at velocity 0 instead. Based on what I'm seeing in the console, all Note On at 0 velocity messages are being received by Usine so I'll try trapping those instead.
I'll let you know how that goes.
Regards,
Scott
Unread post by woodslanding » 10 May 2012, 23:28
I think a lot of controllers work this way.... but if you want release velocity, you need to use real noteoffs.
Not a lot of release velocity enabled controllers out there!
Users browsing this forum: No registered users and 136 guests
