Video pb
Ken29
Unread post by Ken29 » 02 May 2012, 19:15
Hi guys,
I work at the moment on an installation with sound and video. My video file in an .avi H264 720x576 and I use a projector (1024x768) with a 4x3m image. If I play the video with the media player, it is very clean, if I play it with Usine, it is dirty and pixelized... Any idea ?
PS : I'm in a rush, the opening is on next Tuesday...
Kenan
Unread post by nay-seven » 02 May 2012, 19:38
The video player is really simple actually and video formats are sometimes complex, maybe the best way is to convert 20 seconds with different resolution /codec and test ?
And maybe use the same ratio in the player and the projector ( for example 1/2 of the projector :512x384 )
Unread post by senso » 03 May 2012, 10:43
also take care about the frame rate.
24fps is the default in Usine but can be changed in the setup/midi in
Ken29
Unread post by Ken29 » 04 May 2012, 17:32
Hi guys,
I resampled my video to 1024 x 768 wich is the proj matrix, it really improved the quality.
I had another pb, apparently, Usine doesn't seem to like >1go video files, after 1go, Usine stop reading the file and the last part of the video is black. I had to reduce the quality of the video.
Now I have a bigger problem. I use the sampler during the video playback, even in full screen, I have a Usine notification for peak creating, is there's a way to make it not appeared ?
Unread post by nay-seven » 04 May 2012, 18:47
About the peak creating process, generally it's happen only the first time you run a new sample, you'll don't have this notification the next time .
Ken29
Unread post by Ken29 » 04 May 2012, 18:54
The patch is designed for a 3 weeks exhibition with new samples recorded all along... The solution would be to buy a dual display graphic card but I have no budget and the computer is featured with old AGP an PCI Slots... Has someone ever tried, 2 graphic cards on the same mother board ?
Kenan
Clearscreen
Unread post by Clearscreen » 07 May 2012, 04:35
A possible solution might be to play the video from VVVV instead and control vvvv using OSC from Usine? vvvv's a lot more flexible in terms of what video it can play and how you can stream it.
Ken29
Unread post by Ken29 » 08 May 2012, 23:41
Thanks for the answers, I might try vvvv. At the moment, Olivier has implemented in a new version of Usine the possibility of hiding the messages wich is enough for me.
Kenan
Clearscreen
Unread post by Clearscreen » 09 May 2012, 03:03
Nice one Senso! :D
Users browsing this forum: No registered users and 32 guests
