OSC: Usine to Usine
r.erorr
Unread post by r.erorr » 10 Apr 2012, 19:43
Hi, I can't establish simple OSC connection. I think there nothing wrong about LAN connection, firewall etc., cause I can share the files and folders without problems. But I can't send OSC from one PC usine to another PC usine.
1. global setup OSC is ON, and I can see outgoing messages
2. But I can't receive any messages on second PC
Unread post by nay-seven » 10 Apr 2012, 20:58
it's not the same to share files and to send/receive OSC,
about firewall better to disable it to test, then check Port number, etc
have you read this wiki page ?
r.erorr
Unread post by r.erorr » 10 Apr 2012, 21:23
Yes, firewall and defender is off. I read the wiki also. Just one question about ports, do I need to configure ports somewhere external to usine?
Unread post by nay-seven » 10 Apr 2012, 22:11
no, only in OSC modules
OSC works fine in Usine, so must be in your wifi/ethernet configuration ?
r.erorr
Unread post by r.erorr » 11 Apr 2012, 16:39
ok, now its not patching question enymore...
but when you said "it's not the same to share files and to send/receive OSC" do you mean there is something I need to configure on my PC? I know only these steps IP adresse, subnet mask, workgroup, ping and firewall off - thats all.
Unread post by nay-seven » 11 Apr 2012, 19:47
I'm not a specialist myself and there's many parameters to consider , so maybe you know more about this than me.
but when you create your network in Ethernet i remember windows propose you several choices..?
any chance to test with an other PC in wifi mode..? or with an ipod or android phone ( with TouchOSC for example) ?
I've also see this recently, don"t have test yet but seems to be a cool solution for live show,
http://www.connectify.me/
will ask on the general forum if someone use this
r.erorr
Unread post by r.erorr » 11 Apr 2012, 20:05
ok, thanks, I will try...
Users browsing this forum: No registered users and 44 guests
