Hey, Usiners.
I'd love to incorporate a midi pitch bend w/ vibrato fader into a patch. What I'd like to do is similar to the y-axis of the Korg XY joystick. What i'd like this fader to do a full bend of the pitch up/down and add vibrato once the value reaches nearly to the max, say 115/127. I'm sure this is not a very complicated thing to do, but I have no idea where to start. Thanks, friends.
Todd
Second Question: Pitch bend + vibrato
here a quick test, I've create the vibrato in audio mode , cause not all VST recognize CC 7 a volume
Download
Download
Nay7,
Thanks so much, man! The patch works great. I'd never used LFOs before, but now that I'm familiar, I'll begin incorporating LFOs and ramps into my patches. Anyway, the only changes I ended up making to your original patch were substituting the Moody shifter for the stereo volume, splitting the out-going audio signal, and adding in a cross-fader and smooth the transition between flat and vibrato states. Again, I really appreciate your sharing of your expertise.
cool, glad you've finding your way
