voice on/off
r.erorr
Unread post by r.erorr » 08 Mar 2012, 13:10
I'm bit confused about how "patch on/off" module work. Is it possible to switch on/off different voices in polyphonic subbpatches?
jeanrene
Unread post by jeanrene » 08 Mar 2012, 14:08
use a "patch on/off" per patch or subpatch,
it work on the patch in which it is, so it deactivates subpatches with the whole patch.
The only interest is to save the cpu, the downside is a slight slowdown when the patch is switch.
I prefer to lighten my patch to use this function, however this should be interesting for effects that require a lot of resources.
Others surely know better than me this function
PatcherKit at work.
Unread post by nay-seven » 08 Mar 2012, 15:02
yes jean rené, but this don't work for polyphonic patches, actually you can't turn off individual poly .
r.erorr
Unread post by r.erorr » 08 Mar 2012, 15:10
Strange, but something happens when I add patch on/off in polyphonic sub-patch, because it reduce CPU any way, thought not as much as would expect.
Unread post by nay-seven » 08 Mar 2012, 15:43
ouups, yes, you're right, if you add a switch (external to your sub-patch) to control the on/off module, you can turn them off , just avoid to turn off the first one if you have a sampler inside
never test this way before
r.erorr
Unread post by r.erorr » 08 Mar 2012, 19:48
Pfff... I start this topic because on/off module does not work. I'm pretty sure that I saw - module was off, but sampler continued to loop. Don't know why, but it works now. There is no need for external switch, Nay. !?
