sequence with start and ending points
tanabarbier
Unread post by tanabarbier » 11 Nov 2011, 18:25
I'd like to be able to dynamicaly change the start and ending point of looping of a steps modules, or seqswitch, without having it changing it's speed. As anyone a solution for that ?
Thanks !
Unread post by nay-seven » 11 Nov 2011, 18:44
here an old one I've:
download
tanabarbier
Unread post by tanabarbier » 13 Nov 2011, 18:09
It was indeed a very simple thing to patch, thanks a lot, it is just what I needed !
silent
Unread post by silent » 18 Jan 2012, 09:52
I've tried to do the sequencer patch purposed by Nay-Seven to restart accordingly to the auto restart Synchronization but I have an issue.
The sequence don't want to restart at the first step, it always start with the second :(
I'm quite new to Usine so that should be a dumb mistake, but I can't resolve it by my own.
Thanks.
here's the modified patch:
Download
Unread post by nay-seven » 18 Jan 2012, 10:39
strange, works fine here...?
Set all the notes to low values except the first note , you don't hear the first one..?
silent
Unread post by silent » 18 Jan 2012, 11:22
Thanks for your quick reply Nay!
I've just tried your Tips but it still don't want to play the first note on restart,
I mean the first note is only played after a the first loop iteration.
It's pretty confusing because the cursor is well positioned at the beginning of the sequence.
I've tried different system setup but nothing to do.
Unread post by nay-seven » 18 Jan 2012, 11:36
ok, i understand now, in your clock beat sub-patch , change your 1 to 0 module for 0 to 1 , will works
silent
Unread post by silent » 18 Jan 2012, 11:54
It Works!
Thank you so much.
Clearscreen
Unread post by Clearscreen » 19 Jan 2012, 00:44
Just listening to the mix on your site silent - like it a lot! Dl'ing now :D
Users browsing this forum: No registered users and 150 guests
