Patch Zoom In/Out and Navigation
CleverConQueso
Unread post by CleverConQueso » 08 Dec 2011, 23:39
How about attaching the scroll wheel on the mouse to a zoom in and out of the patching window?
-it would be useful for getting around a big patch
-could possibly allow for a zoom in to make the connection tabs bigger
-sometimes if the patch window view into the work space slides far from the content, it would be nice for finding your way back to the elements
Also how about connecting the backspace key to the same action as double clicking in an empty space in the patch window so that you can change patch depth without using the mouse?
-CCQ-
Unread post by 23fx23 » 09 Dec 2011, 01:15
that would be great, but (i suppose) a real zoom would be quite hard to implement, in a modular particle system i use, there is something i find a good compromise wich is a small window added on corner of patch that act as global map, kind of 'bird view', so you can see if there is stuff out of the screen and quick navigate thru the patch cliquing on it.
Unread post by senso » 09 Dec 2011, 09:03
Not easy to implement with the actual graphic engine.
I'm not sure I understand?
It's a goo idea, I'll think about this suggestion.
-a small window added on corner of patch that act as global map
Not easy but not impossible... Let me think about it.
CleverConQueso
Unread post by CleverConQueso » 09 Dec 2011, 18:57
I figured it was probably not do-able given the framework or you would have probably done it already.
Regarding "the work space slides far from the content" - In my case, sometimes I'll open a patch and the window will appear empty. I'll slide around looking for my work but can't find it. It concerns me and plus I can't make changes so I save/quit/relaunch and everything's usually fine. Yesterday when this happened, I slid the window around in a grid pattern until I found the patch contents which is good news, but time consuming.
Thanks for looking at it,
-CCQ-
Unread post by nay-seven » 09 Dec 2011, 19:20
remember you can always right click on any object (on the control panel ) and use the find in patch feature...;)
CleverConQueso
Unread post by CleverConQueso » 09 Dec 2011, 19:34
Yep. Thanks. I often organize into sub-patches which makes it hard to find a top level object. So backing out of a sub patch using double-click brings me back to nowhere. It's not a big deal to me - it works out - but it was a use case for the zoom feature.
Unread post by woodslanding » 10 Dec 2011, 05:31
Also, you can select all and cut and paste using key commands. You'll lose connections to the parent object but it's probably easier than restarting.
Users browsing this forum: No registered users and 125 guests
