Fades in and out when looping
tanabarbier
Unread post by tanabarbier » 06 Nov 2011, 23:54
I'd like to find a way to put short fades in and out at the beginning and ending of the recording of a loop, to avoid clics. I was thinking to use a ramp, starting when rec is pushed, and an other when rec is released, and a data delay to wait until the ramp ends to stop recording, any advice ?
My biggest problem is with the quantized loops, for the fade out, how could I make the ramp start a few ms (it's own duration) before the end of cycle (or any other quantize value) ?
Any suggestion is super welcome !
Thanks !
r.erorr
Unread post by r.erorr » 07 Nov 2011, 00:30
Hey, I had the same problem, and my solution is here. there are two samplers I use. you can double-klick on "crossfader" and configure the position and way how the crossfade increases and decreases.
I use mono samplers but it's easy to adapt for stereo or multi-channel.
http://www.sensomusic.com/forums/upload ... ssfade.wkp
tanabarbier
Unread post by tanabarbier » 07 Nov 2011, 05:07
Thanks for your answer,
I might havent understood how work your patch, or I explained badly what I need, but I can't make it do what I want.
I tried a bit tonight, and here is the patch :
http://www.megaupload.com/?d=XGWRT4SK
I'm not shure it works well, and my problem is with quantized loops, the way I'm doing it the loops will have a duration of, for exemple, one bar plus the fade out time, and so it won't be that much "quantized"...
When something is being quantized there is a fader on the up left corner of usine, is there a way to colect the data coming out of this fader ?
Unread post by nay-seven » 07 Nov 2011, 09:50
have you check the Bar recorder patch in the browser/usine/sampling..?
there 's also some addons from GDlive and joffo around this i think
GDLive
Unread post by GDLive » 07 Nov 2011, 22:16
I have tried a lot of thing in thoses fade in out questions..
Last time, I used ASR modules and in fact I retain it for my new patch, I suggest you to try that, because ASR does a lot of the ramp job and parametrize
http://www.sensomusic.com/forums/uploads.php?file=2011-11-07%2022-14-22.png
tanabarbier
Unread post by tanabarbier » 09 Nov 2011, 00:22
First the one for quantized loops, I used the bar recorder as a base.
It seems to be working, could anyone check this ? I'm really not shure...
http://www.sensomusic.com/forums/upload ... 0fades.pat
Thanks a lot !
