knobs and sliders sensitivity
you can do this, it's in SET LAYOUT-->TOUCH HI PRECISION unfortunately it only works with a touchscreen, not with the mouse. I seem to remember that it used to work with my mouse back in V4. Or maybe it was that I was using a touchscreen in those days.
I don't know how hard it would be to do this, but I would give it a +1.
Generally, I don't know why you wouldn't want the touchscreen and mouse to behave as similarly as possible (but there may be things I haven't thought of
martignasse
hi,
keep the shift key pressed while you drag and you are in the high precision mode with mouse
and you can tweak the precision factor value in the layout panel
hope it help
hope it help
YES , the "shift" works, you are right. I didn't know.
It seems like Touch High Precision is broken.... I tried it on knobs and sliders. Both track their values 1:1. The control range is just from the top to the bottom of the component, even with precision at 10.
Strange... 10 works fine for me, although 15 or 20 would be betterwoodslanding wrote:It seems like Touch High Precision is broken.... I tried it on knobs and sliders. Both track their values 1:1. The control range is just from the top to the bottom of the component, even with precision at 10.
Okay, I realized I had touchscreen mode disabled in preferences.
Can someone explain to me exactly what this mode does?? I had some reason for turning it off, I can't remember now.
I'll look it up in the wiki.
cheers,
-e
cheers,
-e
Users browsing this forum: No registered users and 63 guests
