knobs and sliders sensitivity
r.erorr
Unread post by r.erorr » 01 Nov 2011, 17:08
Sometimes it's very useful to make very precise movements, but sliders and knobs moves so fast and incorrect. It would be great if I can change the sensitivity, how fast or slow the the sliders increases or decreases.
Unread post by woodslanding » 01 Nov 2011, 17:35
you can do this, it's in SET LAYOUT-->TOUCH HI PRECISION unfortunately it only works with a touchscreen, not with the mouse. I seem to remember that it used to work with my mouse back in V4. Or maybe it was that I was using a touchscreen in those days.
I don't know how hard it would be to do this, but I would give it a +1.
Generally, I don't know why you wouldn't want the touchscreen and mouse to behave as similarly as possible (but there may be things I haven't thought of ;)
martignasse
Unread post by martignasse » 01 Nov 2011, 19:42
hi,
keep the shift key pressed while you drag and you are in the high precision mode with mouse ;)
and you can tweak the precision factor value in the layout panel :)
hope it help
r.erorr
Unread post by r.erorr » 01 Nov 2011, 19:52
YES , the "shift" works, you are right. I didn't know.
Unread post by woodslanding » 01 Nov 2011, 20:22
It seems like Touch High Precision is broken.... I tried it on knobs and sliders. Both track their values 1:1. The control range is just from the top to the bottom of the component, even with precision at 10.
r.erorr
Unread post by r.erorr » 01 Nov 2011, 20:50
woodslanding wrote:It seems like Touch High Precision is broken.... I tried it on knobs and sliders. Both track their values 1:1. The control range is just from the top to the bottom of the component, even with precision at 10.
Strange... 10 works fine for me, although 15 or 20 would be better
Unread post by woodslanding » 03 Nov 2011, 01:49
Okay, I realized I had touchscreen mode disabled in preferences.
Can someone explain to me exactly what this mode does?? I had some reason for turning it off, I can't remember now.
I'll look it up in the wiki.
cheers,
-e
Users browsing this forum: No registered users and 111 guests
