Deafult MIDI 'New Patch' Template
CleverConQueso
Unread post by CleverConQueso » 05 Oct 2011, 22:13
When you drag a VSTi into an empty patch, Usine creates bypass, show, MIDI and audio connections. Is this template available for editing to add connections, or change formatting?
- CCQ -
Unread post by nay-seven » 05 Oct 2011, 22:42
Actually no, cause this parameters are the only one that are commons to all VST.
But if you regularly use a specific VST with some personal connections, you can create a sub-patch and recall it with a template from empty area for example..?
Unread post by nay-seven » 05 Oct 2011, 22:55
Of course, if you put your vst in the same dir than the template ( not sure we can use path in IML ) and create all links in this template , can also be a direct solution..
CleverConQueso
Unread post by CleverConQueso » 06 Oct 2011, 18:51
Thanks, Nay-Seven. I do have about 6 favorite synths I go to all of the time that would probably make sense to wrap them up in a patch.
