New add-on /VST Homing Pad
Announcements
Unread post by nay-seven » 03 Oct 2011, 15:09
In our creative process, we often find ourselves trapped by our habits. If for example, you systematically
create your rhythms using a kick and a snare, Homing Pad is for you.
Homing Pad is a musical , creative and easy-to-use tool that allows you to generate grooves or melodies
in an instant and completely intuitive way.
And since nothing is more spontaneous than movement and gesture, Homing Pad uses this method
to allow you to explore rhythms that you otherwise would not have thought of.
So you say “ok, that is nice, but what is Homing Pad?”
A quick click here should satisfy your curiosity: Youtube link
Download in the add-on section and as VST on the free download page
More infos on the Wiki Page
Note : This patch/VST contains samples from Waveshaper kits
joffo78
Unread post by joffo78 » 03 Oct 2011, 15:31
nice job nay !
it seems to be very simple and very fun to make music with your addon. !
Unread post by nay-seven » 03 Oct 2011, 16:20
Thanks joffo, it's a collaborative work but most of the motor/job was done by senso....;)
Clearscreen
Unread post by Clearscreen » 04 Oct 2011, 00:42
WOW! That's a pretty great take on sequencing. I did something similar a while back using midi, but didn't take it as far as this - really cool!
r.erorr
Unread post by r.erorr » 04 Oct 2011, 21:02
Excellent!
Floego
Unread post by Floego » 04 Oct 2011, 21:34
really nice interface!
CleverConQueso
Unread post by CleverConQueso » 05 Oct 2011, 05:10
Homing Pad presents some really interesting ideas about interface. And it sounds good, which is important. I'm going to play with the patch and try out some step sequencer ideas. Amazing, creative work.
- CCQ -
pro65
Unread post by pro65 » 12 Oct 2011, 20:18
Having a little problem using with pro tools 8.5. any body else?
Unread post by nay-seven » 13 Oct 2011, 09:02
Welcome pro65, can you please report bug by mail
r.erorr
Unread post by r.erorr » 29 Jan 2012, 11:49
Hi, everyone and Nay...
Here I made something very very simple, but the same trajectory concept works like homing pad
http://www.sensomusic.com/forums/upload ... ampler.pat
Unread post by nay-seven » 29 Jan 2012, 12:46
great one, r.error , my imagination engine can easily decline this in multiple little ones, with divide/multiply tempo...and so ;-)
btw, can i suggest you to maybe add this as a add_on and add it in the Add-ons discussion topic for a better visibility..?
Users browsing this forum: No registered users and 263 guests
