Saving a midi file
noise2sine
Unread post by noise2sine » 25 Sep 2011, 15:09
i don't manage to save a midi file the way i record it ! Does anyone encounter that kind of problem ? I'm just using the Mustang Patch and a piano roll ! i can see in the piano roll the different note length, but when i "save as" the file is different in term of note length ! they have all the same length ! When i open the file in Ableton Live, it's the same,all notes have the same length !
I don't get it ! i'm not using quantification either.... is it a bug ?
Help :)
Floego
Unread post by Floego » 26 Sep 2011, 00:25
hi there,
why don't you try to post an example of a saved midi file in order to test the problem? :)
Unread post by nay-seven » 26 Sep 2011, 06:15
yes, or maybe better an example patch, cause i can't reproduce this here..
noise2sine
Unread post by noise2sine » 26 Sep 2011, 11:10
ok i will post an example tonite
noise2sine
Unread post by noise2sine » 12 Nov 2012, 11:47
After many turns,i'm still facing the same problem. I have uploaded a piano roll . the first midi file is the one recorded, and the second one is the first one saved and then imported . I don't understand why it's not the same ?
http://www.sensomusic.com/forums/upload ... ifiles.pat
Can you help ?
Unread post by nay-seven » 12 Nov 2012, 14:23
yes, you're right
not always easy to reproduce, works sometimes more when only 1 measure and from preset 1
we have to to investigate, thanks for your feedback
seamus
Unread post by seamus » 14 Nov 2012, 10:24
i have had many problems trying to save midi files. I was using a wind controller sending aftertouch data and note ons and offs. I had similar quantizing effects that seemed to randomly happen.
Unread post by nay-seven » 14 Nov 2012, 11:12
yes, we know there's several improvement to do for this piano roll, we hope to have this resolved for the new version /product coming..
( btw, hope all is fine for you seamus, was thinking about you recently when seeing New York under the water)
Users browsing this forum: No registered users and 196 guests
