replace/substitute fonction in right click
jeanrene
Unread post by jeanrene » 13 Sep 2011, 10:22
to replace one element by another without re-linking,
for example to replace an "xy 2balls module" by a "xy 4balls module".
an another exemple is to remplace easily a fader by a vertical fader or a knob,
or a vst (midi in, parameters, audio) by an another vst.
PatcherKit at work.
Unread post by nay-seven » 13 Sep 2011, 11:12
you know there's yet the drag & drop with [alt ] pressed to replace module or VST ?
jeanrene
Unread post by jeanrene » 13 Sep 2011, 19:58
nay-seven: thanx :D ; every time I make a suggestion it is already integrated. I suggest now a printable manual in pdf.
cleverconqueco: :lol: thank you I feel less alone
PatcherKit at work.
