to replace one element by another without re-linking,
for example to replace an "xy 2balls module" by a "xy 4balls module".
an another exemple is to remplace easily a fader by a vertical fader or a knob,
or a vst (midi in, parameters, audio) by an another vst.
replace/substitute fonction in right click
you know there's yet the drag & drop with [alt ] pressed to replace module or VST ?
CleverConQueso
nay-seven: thanx
; every time I make a suggestion it is already integrated. I suggest now a printable manual in pdf.
cleverconqueco:
thank you I feel less alone
cleverconqueco:
PatcherKit at work.
Users browsing this forum: Bing [Bot] and 10 guests
