REC: save outputs as...
will be be probably added in futures versions. but I can't say when...
ErotiCore SteNch
yes please +1
multiphone
For once I can answer before Seven Nay!
But after Senso
To do this 2 Solutions:
1°) If your audio interface is an RME, the Digicheck utility is perfect for that. You can record everything that comes out of your sound card and save the file in mono or interlaced files
http://www.rme-audio.de/en_downloads.ph ... _digicheck
2°) With Bidule VST (http://www.plogue.com/?page_id=274) in Usine you can do the same things.
Best
Best
of course there is also free ways
3) Jean-Marc Duchenne plugins multi rec 6, 16, 24 channels, but record output has a strange format.
http://acousmodules.free.fr/acousmodules6_en.htm
4) We can create it on Usine from mono or multichannel sampler modules, but anyway easy to do from record panel, if this is not hard to add that option
Users browsing this forum: No registered users and 105 guests
