I have seen in some instruments there is knob for octave shifting.
I would like to create a patch to control that knob with my midi keyboard with notes.
So far all i get is 0 and 1, so knob is either on minimum or maximum when i send notes.
Can some one help me?
Cheers!
Controlling knob with midi notes?
You mean something like this..?
sub-patch change scale is in Modules/data/data manipulation
Thanks for the quick response!
hmm...could be, im not sure.. there are too much knobs
I know i did that patch long time ago.
But i cant remember exactly how i did it. :rolleyes:
I know its simple.
It was something like this:
http://imageshack.us/photo/my-images/3/noteknob.jpg/
So when i press the first note on midi keyboard knob goes to 1 and when i press last note it goes to value 127 and everything in between.
Is that what you are trying to explain to me with your example?
I know its simple.
yes, exactly, you can keep only the sub-patch, faders are only here to set the values
Users browsing this forum: No registered users and 43 guests
