'patch cable' removal
roby
Unread post by roby » 25 Apr 2006, 02:59
hi, would there be an easier way to remove/delete the virtual cables? like select->delete perhaps?
Unread post by senso » 25 Apr 2006, 23:34
In the next version you will able to select a wire and delete it.
jean-marc duchenne
Unread post by jean-marc duchenne » 08 May 2006, 14:42
+ 1
And perhaps also the possible use of the Delete key together with actual Ctrl+X to delete a module ?
And what about the lasso selection of modules with a modifier key ?
Habits, habits...
Unread post by senso » 08 May 2006, 15:44
I know that I should improve all the editing functions (group select, wire select/delete, shift+select, etc)
I'm working on
lvr
Unread post by lvr » 06 Jun 2006, 13:11
+100 !
Unread post by senso » 06 Jun 2006, 22:13
In the 1.019 version, I add the possibility to select a wire and delete it. It's the first step to a general improvement of the interface.
My next goal is the "multiselect" (with shift or ctrl)
lvr
Unread post by lvr » 07 Jun 2006, 00:44
Great !
jean-marc duchenne
Unread post by jean-marc duchenne » 23 Oct 2010, 10:59
+100 !
Always waiting for it..................................................................................
multiphone
Unread post by multiphone » 23 Oct 2010, 11:36
Yes !
I sign the paper.
But, it's probably harder to do than i think.
Best
HB
Lines / Points / Squares
http://www.hervebirolini.com/
